Re: Restoring an IH Farmall 140.....UMBRELLA IDEAS??
Posted by mkirsch on March 08, 2012 at 13:16:46 from (64.80.110.75):
In Reply to: Restoring an IH Farmall 140.....UMBRELLA IDEAS?? posted by rtr on March 06, 2012 at 07:38:56:
If you've got the "deluxe" seat on the 140, it'll work just fine.
That bracket would make quick work of the problem. No welding, no fuss, no muss.
The seats were made by the same manufacturer apparently. I've seen the JD cushions and IH cushions together, up close. They're identical except for color.
