Posted by Janicholson on March 09, 2012 at 09:15:04 from (67.72.98.45):
In Reply to: FARMALL H CLUTCH posted by S2710 on March 09, 2012 at 08:47:06:
In addition to Zachary's point, the clutch disk may be dragging a small amount on the Flywheel or Pressure plate when the pedal is depressed. If you have the free play set to one inch (measured from the platform to the pedal stop when pushed in gently by hand) the transmission should slow and stop allowing shifting within 12 seconds with the pedal pushed at least 6" down. If it does it is normal. if it doesn't, the disk is dragging, splines on hub are rusty, disk is warped some, or the pilot bearing is in need of lubrication. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
