Re: FARMALL H CLUTCH
Posted by S2710 on March 09, 2012 at 10:13:25 from (98.143.227.89):
In Reply to: FARMALL H CLUTCH posted by FC Andy on March 09, 2012 at 08:47:06:
The clutch was adjusted properly, and I have the pump out so I can depress the clutch and the disk is loose and slides back and forth on the splines. With the clutch pushed down and transmission in neutral I can reach up and grab the shaft and it is sticking but I can get it to turn and then it is free and spins fine let the clutch up and then push it in and it is sticking again. I have pumped grease in the zerk on the flywheel but that doesn't seem to help. I will check replace the pilot bearing in the flywheel if necessary but how about the pilot bearing on the input shaft in the transmission?
Bob
