Posted by pete 23 on March 09, 2012 at 10:38:45 from (74.32.238.142):
In Reply to: 806 died posted by c-man on March 09, 2012 at 09:54:59:
Did you see any "coffee grounds" come out of the side cover on pump. That is usually what is left of the governor ring when it shells out. If so, you will want to have pump repaired soon to avoid shearing off the governor weight retainer pins and having no engine speed control. You can remove ball temporarily if plugged but not good to run that forever. If you do not find anything in pump, I would take an oil filter off and examine for bearing or piston material. I have seen them get pretty tight and free up again and run for a while.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
