Re: New Case-IH front rims with tabs
Posted by mkirsch on March 09, 2012 at 10:40:20 from (64.80.110.74):
In Reply to: New Case-IH front rims with tabs posted by Yooper Farmall on March 09, 2012 at 06:41:12:
Jack the front end up, hook the top lug over the hub, let the tire drop down behind the hub, and swing the bottom in. Easy.
The new tabs are spaced to give you the same offsets as the old loops. All you need to do is turn the wheel around for different spacings.
