Here again,using the the term "6 volt and 12" volt coil is kind of inaccurate!
After reading what some of the electrical experts have stated on here,the ONLY way I am sure WHAT a coil actually IS ,is to check them ALL with an Ohm meter.I bet you could take a dozen coils made by different manufacturers, Both advertised as 6 or 12 volt,test them with your ohm meter,and get all different results???They would probably fall within a certain range,but would be different.
Another thing also.ANY component you install BEFORE that coil is causing some kind of resistance! So if you have a key switch that has dirty contacts inside,or if you ran 50 feet of wire from that key switch to the coil,or installed TOO big of a ballast resistor,ECT,ECT,ECT,ALL of these can drop what is actually making it to the coil!!!! When replacing a coil,you might want to check the WHOLE ignition system out.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
