Re: installing pistons rings
Posted by Janicholson on March 10, 2012 at 13:19:15 from (67.72.98.45):
In Reply to: installing pistons rings posted by SDE on March 10, 2012 at 09:11:06:
The oil ring needs to have its Rails at opposing sides. The others should be spaced at least 45* apart. make sure the ring grooves are clean to metal. (used pistons) Dip the piston in engine oil just before insertion. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
