Wire brush the location to remove loose material. Dry with a blow drier if wet at all. Use JB weld to fill the void. Use a piece of tin to form the outside contour by over filling a little, put some 1/4" holes in the shaping tin to allow the excess to escape. Use a thin coat of grease on the tin to act as a release agent. Wrap the tin on the repair and wrap it with nylon string stretched so it smashes the JB weld into conformation with the roundness of the pulley. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
