Re: Saga of Stuck SH input needed
Posted by ken house on March 10, 2012 at 15:11:23 from (173.242.240.50):
In Reply to: Saga of Stuck SH input needed posted by Va Gasman on March 10, 2012 at 04:57:21:
remove spark plugs, take compressed air and blow everything out of cylinders. most likely water on top of piston, so penetrant cannot get to rust. add penetrant and start over. failing that remove oil pan and head.
i put a jack under rod bearing and raised front of tractor off the ground, then used screwdriver in flywheel, before engine came loose. engine runs fine.
good luck
