Re: SMTA PTO - Correct police question
Posted by Harold Hubbard on March 11, 2012 at 06:37:11 from (205.209.16.24):
In Reply to: SMTA PTO - Correct police question posted by sflem849 on March 10, 2012 at 15:38:42:
The easiest way I have found to replace ANY PTO with a long shaft, is to slid a piece of pipe onto the PTO shaft. Then, with a hoist of some sort, or your handy dandy resident gorilla, lift the unit at the housing,and use the pipe to balance and guide the long shaft into the transmission.
Back when my back was younger, and I was dumber, I have done lighter weight ones (H, M, and even a C) by main strength and ignorance. The C, Super C is kind of clumsy and miserable because the offset gears put the input shaft above the output, and the gear case wants to turn over as soon as you let go of the input.
