Re: 574 diesel injectors
Posted by jimb2 on March 11, 2012 at 10:04:06 from (174.115.9.174):
In Reply to: 574 diesel injectors posted by makin hay on March 11, 2012 at 09:09:49:
Hi, make sure everything is very clean. The injectors pull out but you should drain coolant down some as there is a brass sleeve that may pull out with injector and that would let coolant into cylinder. I believe IH made a tool for the German Diesels to pull the injectors.
JimB
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
