Posted by Kevin Fritsche on March 11, 2012 at 13:24:06 from (70.241.79.223):
Hello, I apoligize in advance for the lengthy first post but here it goes. I am converting an "H" to 12 volts for my aunt. I read a lot of posts on here about the conversion but have some questions. I plan to use an Optima gel battery and will have to build a new battery box. It looks like width and height of the original box are OK but not the length. It appears it needs to be about 1 1/2" longer. Is there room to accomodate a slightly larger (longer) battery box? I will use a diode instead of the light in the alternator circuit. What amp rating does the diode need to have? I read these tractors were originally positive ground systems and the ammeter will read backwards which is easily corrected. How do you get the starter rotation correct? Some of the info I see is for the "M". Are the "M" and "H" electrical systems the same or close enough that the "M" info also applies? Will the standard pully on a typical alternator spin it fast enough to charge effectivly? I will take pictures and try to post them when finished. Thanks, Kevin
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
