Re: wd9 Starting Problems
Posted by El Toro on March 11, 2012 at 15:26:38 from (108.3.225.57):
In Reply to: wd9 Starting Problems posted by Dave Meisner on March 11, 2012 at 14:10:30:
Hold your hand over the throat of the carburetor and see if has good suction when making a start.
Poor suction means low intake manifold vacuum. You need good suction to pull that gas into the engine. You may just have a leak on the manifold. Snug up the bolts or nuts on your manifold. Make sure your valves have enough clearance. Hal
