Posted by Janicholson on March 11, 2012 at 16:14:14 from (67.72.98.45):
In Reply to: wd9 Starting Problems posted by Dave Meisner on March 11, 2012 at 14:10:30:
A couple of added ideas: They take a lot of choke at first. They often have a float lifting linkage that shuts off fuel delivery when running on Diesel. They have an ignition shutoff that grounds the mag, or opens the ignition voltage supply if point and coil ignition. If these are OK, it should start. Starting by pulling is OK, just don't pull it faster than it can go in a particular gear, and remember it will not inject fuel if the engine is turning faster than the control lever is set to run. It will take as much as 1/2 mile of towing to get it warm enough to run. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
