Re: 574 diesel injectors
Posted by pete 23 on March 11, 2012 at 16:49:23 from (74.32.238.142):
In Reply to: Re: 574 diesel injectors posted by makin hay on March 11, 2012 at 12:09:11:
I wouldn't think you would need to replace the brass sleeve in this case. There are no o-rings to replace in the injection nozzle, it is all highly polished lapped surfaces. Some times though, a leaking fuel return or even injection line can run fuel down in along side of those and make it appear to be coming from the injection nozzle itself. But, I have seen the injection nozzle leak also. The o-ring on top end is just to keep crud out of sleeve.
