Re: 464 value
Posted by outdoors on March 11, 2012 at 18:17:11 from (76.11.75.212):
In Reply to: 464 value posted by wijim on March 11, 2012 at 11:13:00:
The diesel version was a d179, 3 cylinder. Great little motor that was used for many years (454, 484, 485, 495,...). Easy on fuel and tough. Start pretty well in cold. Same rear end and transmission used on much larger tractors. Good parts supply through scrappers or case/ih.
I picked up a little 454 last fall. Good brakes and three point power. Check the park brake as most don't work. Once someone drives off without releasing it, the brake band gets burnt and can distribute lining material through the hydraulic oil. Worth checking the filter if considering. Bands require some work to replace. Most don't bother.
