Re: wd9 Starting Problems
Posted by sflem849 on March 11, 2012 at 18:49:09 from (69.197.84.39):
In Reply to: wd9 Starting Problems posted by Janicholson on March 11, 2012 at 18:30:22:
How many thou do you compensate? This guy said a loose .001 I suppose a normal .002 would be about the same.
