Re: In-Frame O'haul kit-350U?
Posted by linemechanic1 on March 11, 2012 at 22:07:19 from (69.86.135.178):
In Reply to: In-Frame O'haul kit-350U? posted by linemechanic1 on March 10, 2012 at 20:23:51:
Thanks for the info. Sounds like I could make a sleeve puller using a new sleeve for a template to get the diameter right and a slaphammer to knock it up through the top. I do have a freezer and heat available even though I'm working under a tarp strung between two trees. It isn't going any where until it's running and the hydraulics flushed so I can get the loader and backhoe out of the dirt. Not sure about the mains but rod bearings will get replaced. Would an 'undersize' number be stamped somewhere down there if they've been done before?
