Re: Farmall M trany/cluch problems
Posted by Nick Roepke on March 12, 2012 at 13:15:35 from (74.40.147.120):
In Reply to: Re: Farmall M trany/cluch problems posted by rustred on March 12, 2012 at 11:34:59:
it has bean compleatly gone threw and put back togeter with parts that were worn out being replaced engine overhall and trany rebuild the tractor was split and clutch rebuilt the brake drums where in speck so i had the brake bands replaced and all new seals and gaskets allround so i want to know what is not "in-spec." or what needs adjusted because the ENTIRE trans has bean gone threw the dif. checked out alond with the gear sets but it sounds like some thing is a few thns off some where after the cluch i didn't know if the cluch is still parshly engaging, the problem isn't i took a pile of junk and spraypainted it, the problem is i have manny new parts and something doesn't line up.
