Re: advice on buying a M
Posted by Yooper Farmall on March 12, 2012 at 13:31:13 from (141.210.112.16):
In Reply to: Re: advice on buying a M posted by Nick Roepke on March 12, 2012 at 13:19:32:
I really couldn't answer for your engine, but on mine I could guess that 90% of my engine's problem was the valves. My head never had the hardened valve seats installed for nonleaded gasoline and were just plain worn out. I don't think I needed new springs. My head work was between $200-$250. That might be a good place to start. I don't beleive you need to have your cylinders honed, the cylinders are sleeved. Parts are for sale on this site:
Piston ring set $55
Piston sleeves are $56
A whole piston sleeve kit $280
My oil pressure was low so I ended up replacing the bearings also, it was dangerously low when warm, and now the needle is pegged at 75lbs
