Re: 766 engine oil useage
Posted by pete 23 on March 12, 2012 at 19:03:15 from (74.32.238.142):
In Reply to: 766 engine oil useage posted by 1370rod on March 12, 2012 at 18:53:18:
Is this the 360 engine. There were problems with the fit of the sleeve into the block on these engines. Some of it was the top o-ring groove not machined properly and needed a bevel on the bottom side of the groove. Other problems was insufficient clearance in the lower portion of the block. That sleeve has to fit with some clearance without the o-rings on it. In other words the sleeve has to drop right in and be able to easily turn it . Another thing, those Red Power pistons may not have enough piston to sleeve clearance. Go for the high end of the specs.
