Re: alt on 560
Posted by Janicholson on March 12, 2012 at 20:36:17 from (67.72.98.45):
In Reply to: alt on 560 posted by brian brooks on March 12, 2012 at 20:23:01:
This will have relevant info. Two ways to excite the alternator. Use a momentary contact push button to feed 12v to the # 1 spade terminal. Or Put a "T" in the oil pressure sending unit fitting at the block, and use a NAPA supplied "on with pressure" switch. Wire the switch so it gets bat + voltage at one terminal, and the other goes to the #1 Alt spade terminal. Works either way but the first requires your remembering to make it charge. Jim
