Timing is TDC at zero RPM just turning it to set the timing, not running. Put a test light on the terminal going to the distributor (wires connected) with the coil wire grounded and plugs out dist. cap off,(safety) turn the engine with the crank or fan blade. The rotor should point to the #1 plug position just as the light comes on, and just as the timing mark gets to the pointer on the front pulley. This is static timing. Put it together and with a timing light, check to see the running timing (probably close to 22 to 25 degrees. If no advance, or very erratic flashing, the distributor needs to be rebuilt, New springs, and rebushed, then checked for proper advance. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
