Re: How to Break it Loose
Posted by JRSutton on March 13, 2012 at 06:24:08 from (75.130.109.233):
In Reply to: How to Break it Loose posted by llamraf on March 12, 2012 at 19:51:53:
I use a cylinder hone. The kind with the three grind stones.
Just go real easy with it.
I do that to get most of the heavy stuff out. Then would dump some atf in there and let it sit over night.
Only then would I think about trying to break it free. I put a short 2x4 or whatever fits into the cylinder and smack it with a heavy hammer.
Usually that's enough to get them moving. Keep wiping and cleaning.
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
