Re: farmal H electrical problem
Posted by farmalmarkmark on March 13, 2012 at 06:45:40 from (24.29.248.142):
In Reply to: Re: farmal H electrical problem posted by farmalmarkmark on February 24, 2012 at 10:47:45:
Here is the follow up. To review, I had a battery that tested great on specific gravity and put out 6.3 volts per my volt meter. I connected it directly to the starter-nothing happened. Directly to the lights-nothing happened. Got a new battery-problem solved. The lesson for me here is you can have good specitic gravity, good voltage on the volt meter and still have a bad battery.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
