Re: New Case-IH front rims with tabs
Posted by Yooper Farmall on March 13, 2012 at 06:59:57 from (141.210.112.16):
In Reply to: New Case-IH front rims with tabs posted by Yooper Farmall on March 09, 2012 at 06:41:12:
I got this done on Saturday, drove one front wheel up on a 2x4, removed the other rim, ringed it around the hub and attached it to the inside of the hub. It was very tight, I have a little touch-up painting to do on the hub but no worries.
thanks for the advice.
