Re: How to Break it Loose
Posted by John A. on March 13, 2012 at 07:18:28 from (76.1.122.180):
In Reply to: How to Break it Loose posted by llamraf on March 12, 2012 at 19:51:53:
llamraf,"Burn it out"... Since you have the engine torn down you are already 2/3 of the way home.....
Remove fuel tank if its not all ready off, roll tractor out side , make sure all Flammable items are clear of the area.
! Fill the cylinder with the most volume! up with Diesel, add a splash of gas, set it on fire, drink a cup of coffee as it burns, when it has burned itself out drive the piston out from the bottom. the burn time or # of burning will vary from 1 time if the piston is at the bottom of the stroke, to quite a few if the piston is more TDC.
This method will get a engine loose in 1 afternoon!
Just use all fire precautions possible, do not burn your shop down!
Later,
John A.
