Posted by Nick Roepke on March 13, 2012 at 08:14:12 from (64.107.101.25):
In Reply to: head gasket problem? posted by Adam Archibald on March 12, 2012 at 08:36:37:
check the oil bath make sure it aint leaking, and if that isn't the problem the gasket around the valve cover could be leaking, if the tank is the origanal i have had problems with them rusting on the inside and the rust makes it hard for fuel to get to the carb 9 times out of 10 it is a lack of fuel check the sediment bowl and put about a 1/2 inch stand pipe on it (brass or copper, and if that aint it back out the jet pin on the tractor (while she's running warm)and the carb may have crap in it so if it can't be adjusted to run right the carb may have to be taken apart and cleaned/rebuilt, it is commen for the carb to be blocked with rest when the tank has rust in it, i hope you can get it runnin but if all that doesn't fix it that it needs searous help (rings, valves cylinders honed/replaced)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
