Re: 766 engine oil useage
Posted by The tractor vet on March 13, 2012 at 08:36:42 from (75.19.114.43):
In Reply to: 766 engine oil useage posted by 1370rod on March 12, 2012 at 18:53:18:
Like Pete said and i will ad to this . a 766 setting at a 100 Hp is a bit over fueled and being over fueled can cause washing of the walls and fuel not burning can turn to more carbon . Also along with fitting sleeves to block it is wise to FIT PISTONS TO SLEEVES today. One other thing about breaking in a diesel engine is HEAT , if the engine is not getting up to and above 165 degrees and better if it is running 185-195 range the fuel in not getting burnt properly . Making sure that the injectors are all working good also plays in how well your rebuild is going to play out. As for break in OIL myself i have never played into that . I run what is going to be run in that engine . And a better way for break in is TO RUN IT , Now not sayen to take it out and put her on the plow and plow 500 acres non stop but Chore work , haling manure moving bales spreading fertilizer grinding a load of feed if you can load the grinder evenly . And the big thing set it back to being real close to stock or 10% above atleast for the first fifty hours . And make sure that engine temp is at operating temp.
