Re: Re: Re: IH 574 DIESEL W/LOADER
Posted by T_Bone on September 15, 2000 at 07:53:42 from (207.254.53.38):
In Reply to: Re: Re: IH 574 DIESEL W/LOADER posted by TED on September 15, 2000 at 06:35:26:
Hello Ted, Thats simple to tell. Unplug the lines to the loader. If PS is not working then it's something in the PS system. You may have air traped in the PS system and usually all it takes is too keep working the steering wheel letting the air circulate back to the tank.
If the loader system was not bleed prior too you connecting the lines, then you entered air into the system when you pluged the lines in.
You may have to break a pressure joint apart to vent the air.
Make sure your lines are connected correct if they can be reversed.
T_Bone
Post A Followup
: Re: Re: Re: Re: IH 574 DIESEL W/LOADER
