F 20 water jacket gasket- sealant or not
Posted by SDE on March 13, 2012 at 17:24:42 from (174.124.37.184):
I was wondering if a person is supposed to use a sealant when you install the water jacket to the head? Afterall they will be torqued to about 85lbs. I did not see the answer in the achives. The head gasket has the metal rings for all the passages and it said it does not need to be re-torqued. It did not mention anything about sealant and so I did not use any on it. Also I am missing a few nuts for the head. Will any nut with a flat washer work or does it need to be OEM style?
Thank you
Steve
