Problem's carburetor icing. Very common when temp's between about 30 and 55 and with high humidity. Things that help:
- Use minimum choke when starting. Once the engine's running get the choke full open as quickly as possible.
- Immediately after starting idle the engine at 1/2 throttle for several minutes. Or run it at speed under light/medium load. (DON'T let it idle at slow idle until it's fully warmed up!)
- If the still engine dies after running a couple minutes, wait 5 minutes or so before restarting so heat can soak down from the manifold and warm the carb. Or play a hair dryer on the carb for a couple minutes to warm it up.
- If icing is frequent and extreme, cobb up a hose to draw warm air from around the muffler into the air cleaner inlet.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
