Re: Zenith carburetor screw NEED HELP ASAP!
Posted by Coyote Green on March 13, 2012 at 19:16:13 from (67.214.194.155):
In Reply to: Zenith carburetor screw NEED HELP ASAP! posted by Coyote Green on March 13, 2012 at 12:35:36:
I believe I've found what i am looking for, i need to have this tractor running tomorrow, because i have consigned this tractor to a auction for this weekend and it just quit today, i then took apart the carb when i lost the screw.
I believe i have found the correct screw, and i got it all put together. The tractor started right up but now it runs a little rough and then it quit again. I realized it wasn't getting any gas, i drained the fuel lines and it was full of gunk.
I got everything cleaned and then i disassemble the carb and then re cleaned it again.
Now the tractor runs but it's still a little rough when it throttles up and it's a little week on power.
Does anyone have any ideas?
I have adjusted the main jet on the carb 1 5/8's turns out and that's when it runs the best, but it's still a little week.
Thanks for the help
