Re: Disc for H
Posted by gene bender on March 14, 2012 at 17:53:50 from (67.55.227.36):
In Reply to: Re: Disc for H posted by david G on March 14, 2012 at 16:47:04:
Pulling a 10ft with an H will work if you arent going in the ground very deep as 7ft tandem in plowed ground even cornstalks was a good load. It takes a good M to pull 10ft if you are cutting very deep.
