Re: Another A question
Posted by Roger46 on March 14, 2012 at 18:46:11 from (166.250.97.153):
In Reply to: Another A question posted by charlie M on March 14, 2012 at 16:33:06:
Which part can't you get off? Do you have the axle out of the final drive yet or is that what you are removing. Usually that can be removed by driving it out with a wood block from the inside after removing the nut and the lower pan. Removing the axle to replace the axle seal is another story. The outside bearing needs to be removed and it is pressed on the shaft. You need a hydraulic press and a bearing separator to press that off and many times it can come off hard. Need the right equipment. Roger
