Re: Farmall 400 replacing crankshaft walkthrough
Posted by truckerlary on March 14, 2012 at 19:02:03 from (12.19.152.194):
In Reply to: Re: Farmall 400 replacing crankshaft walkthrough posted by Farmall200 on March 14, 2012 at 18:49:43:
I start by removing the front end and working back to the engine. You can take a cherry picker and remove the front bolster with the radiator attached. Just hook your chain up towards the top and it should slide out of the frame rail and then you can carefully lay it down. You might have to loosen the frame bolts at the back of the engine to get it to come out. Make sure you have good blocking behind the engine.
