Posted by John T on March 15, 2012 at 05:26:57 from (66.87.2.216):
In Reply to: M charging posted by Bill Bowen on March 15, 2012 at 02:55:38:
Check at the BATTERY when shes just setting there NOT running a good battery ought to read around 12.6 volts subject to temperature and its state of charge. If running and hooked to a good alternator it should rise from at least 13 to 14.5 or so and over depending on RPM, battery condition, belt tightness and pulley sizes, and the alternator and its voltage regulator BUT IT NEEDS TO RISE IN VOLTAGE TO INDICATE CHARGING
For an ammeter to effectivley register the current into CHARGING the battery or out of DISCHARGING the battery, the battery (often where big cable attaches to starter switch) must be connected to the SUPPLY side of the ammeter while the output of the alternator, plus loads likes lights and ignition, must be connectted over on the other LOAD side of the meter. Ive seen guys mistakenly wire the alternator to the battery side and that way the ammeter dont register its charging.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
