A picture or diagram won't help much. I usually have enough problems getting the ones I take off back on. They have to be bent exactly. Perhaps someone has a good used one, if not I would likely use rubber tubing, although I would much rather have an original. Can your old one be repaired? Look at OEM Tractor Parts web site. I don't think they have them but it is worth a look.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
