Farmall M push Rods
Posted by Luther on March 15, 2012 at 16:50:01 from (166.249.101.18):
Just put a rebuilt head on a 49 M . Went together great . But there is not any clearence. Between the valves and the rockers . # 4 valve does have a little clearence but the rest are tight. Even when I backed the Adjusters out all the way . My thinking is that the Head was milled down to far .?? If that is the case . Is there a shorter Push Rod available ? If so what farmmall would it come out of ?
