Re: Wrong Headbolt Torque
Posted by Janicholson on March 15, 2012 at 17:08:37 from (96.24.99.126):
In Reply to: Wrong Headbolt Torque posted by 400D Guy on March 15, 2012 at 16:02:13:
That one is for sure going to need to be taken out
of the head. If it is a headed bolt, the head might
need to be removed. If it is a stud and nut, and
the bad threads are on the nut, or on the top
threads, the situation is much better in that the
stud can be removed and replaced W/O removing the
head. Tell us what you find. (even a few degrees
of rotation with no increase in torque is a failed fastener. If the block has pulled threads, it can be repaired with a threaded insert. (Helicoil is not the only system, Thread Serts is one other that provides great service. Jim
