Posted by Janicholson on March 15, 2012 at 21:25:39 from (96.24.99.126):
In Reply to: 460Ih pto posted by ldb on March 15, 2012 at 19:17:33:
The lever is intended to both engage the PTO and stop it with internal brakes. Your PTO could be either a Band operated planetary gearset, or a multi disk clutch operated type. In either case, the lever is fitted with latching detents on the handle. In on (rearward) position, the bands or clutches are driving the PTO shaft from the engine (bypassing the engine clutch). In the forward (off) position, A different band is contracted on a drum stopping the PTO. Not just removing power, but putting on shaft brakes. If the lever and linkage have no lost motion(a common issue), and the lever travels to the latching points, and it still turns, the bands need to be adjusted. If it is the clutch style it is not adjustable and will need new clutches. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
