Re: farmall m rear wheel weight bracket??
Posted by George Rausch on March 16, 2012 at 02:55:46 from (64.85.217.137):
In Reply to: farmall m rear wheel weight bracket?? posted by jmducks1 on March 15, 2012 at 19:29:01:
Yep, remember the days when you could single-hand a wheel weight into place, and then hold it, and then get the bolt and nut??
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
