Re: MD Water Trap
Posted by BruceS. on March 16, 2012 at 07:32:18 from (76.15.9.253):
In Reply to: MD Water Trap posted by Haas on March 15, 2012 at 17:59:33:
Can you tell if it's leaking between the bowl and the gasket or between the gasket and the aluminum part? I've not seen the gasket deteriorate on my MD. If you can pinpoint the leak, you could get everything totally dry and then use a tiny amount of RTV on the rim of the bowl, let it set until cured so none would be going into the fuel. This probably is not a great idea, but it might work if the leak is very minor.
