As stated above the rivets are the way to go. RIveting is easy and clean Place the rivet through the bar into the section from th bottom. Place the bar on a heavy steel support. A rail road rail/anvil/scrap iron 1" thick/platform on the back of a 4" vice. The rivet should stick out one to 1.5 diameters from section with the section tight to the bar. Hammer the rivet three or so solid square hits to swell it and shorten it in the hole. Use the Ball end of a Ball Peen Hammer to round out the rivet head by lighter whacks at angles to dome over the head. Leaving hammer marks is SOP. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
