Re: Honing stuck SH cyl walls
Posted by Zachary Hoyt on March 16, 2012 at 15:24:09 from (184.10.233.121):
In Reply to: Honing stuck SH cyl walls posted by VA Gasman on March 16, 2012 at 14:55:34:
The horizontal steering shaft comes out by removing the grill and unscrewing the big pipe cap on the upper bolster, removing the bolt and key by the U joint and spinning the shaft so that the worm gear unscrews from the half moon gear and the whole shaft can be removed.
Zach
