Re: 706 engine weight
Posted by charlieu on March 17, 2012 at 05:57:49 from (209.131.230.214):
In Reply to: 706 engine weight posted by JMP on March 16, 2012 at 10:00:25:
Over the years as I have been designing my splitting stands that I sell I have checked the weight of a few tractor engines after they were split. A 560 diesel with flywheel in place tips the scale at a little over 900 lbs. A 656 with gas engine only weights about 700 lbs when split.
When splitting a tractor remimber that half of the engine weight is supported by the front axle.
I have not checked a 706 but it should not be much different. Hope this helps, charlie
