Posted by charlieu on March 17, 2012 at 11:26:20 from (209.131.230.214):
In Reply to: 560 leaking oil posted by IH Heaven on March 16, 2012 at 20:51:51:
There are a few different places that the leak can be coming from, to locate leaks like this. What I do is split the tractor, and remove the flywheel. Then plug the crankcase blowby tube with a rag. If there is a breather hose from the valve cover to the air cleaner pipe you will need to plug the hole in the valve cover also. Install the bolts that you removed from the flywheel back into the end of the crankshaft finger tight. Now install a air blow gun in the dipstick hole with a little rag and add some (little) air pressure to the crankcase and watch the rear seal area for bubbles. If you spray a little soapy water on the rear seal that will help to find the leak. Let us know what was leaking. good luck charlie
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
