Re: SA tire leaking calcium
Posted by Zachary Hoyt on March 18, 2012 at 09:55:23 from (173.86.126.8):
In Reply to: SA tire leaking calcium posted by scott#2 on March 18, 2012 at 09:21:34:
I had a 14.9/38 tire that was loaded that blew through the rim and I was able to siphon out most of the calcium with a 6 foot piece of garden hose. I started with the hole on top, and after I filled each bucket I would move the tire and rim so that the hole was lower. To start the siphon I just stuck the hose as far in as possible, put my thumb over the end and pulled it out and down into the bucket and let my thumb off the hole, all very quickly. It was not a fun day, but it could have been worse. If you don't already have a hole that big in your tube you might want to just drain it out the valve hole with a small hose.
Zach
