Here is what I have done many times on these steering arms. I believe you have the steering spindle with the snap ring on spindle below arm. Later style spindles had a helix style spline that when you tighten the nut it actually will tighten, kind of like a tapered spline but not quite. They are better but still can get worn loose if not kept tight. Anyway, I take the arm, slice it vertically on front, weld a heavy spacer on each side of split and put a 5/8th inch fine threaded bolt through spacers and tighten bolt clamping arm tight to splines. You need good heavy spacers. Have seen 3/4 inch bolts used also. The quality of the weld is very important.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
