Posted by rustyfarmall on March 19, 2012 at 09:34:24 from (216.248.71.224):
In Reply to: H Hydrolic Fluid Level posted by ewalker@iendeavor.com on March 19, 2012 at 08:50:21:
Sounds like the fill pipe might be a bit short, but if it works, why change it?
The belly pump reservoir holds 6 quarts. Over-filling the reservoir will not hurt a single thing, other than make a mess when the excess squirts out the vent hole in the fill cap. Too much oil is much better than too little. I'd say take a length of wire, make a loop in it so it can't fall all the way in, and then insert it down into the fill pipe, pull it back out, and if the oil on that wire indicates it is within an inch or two of the top, you're good to go.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
